I was wondering, can we have two different folder data cards for folders in a vault?
Regards,
Hidayah
Regards,
Hidayah
Yes you can have two different folder cards for folders in a vault.
You would need to save the folder cards in the respective folders.
Thanks & Regards,
R.Vignesh
No you need not use template for achieving this thing.
Say you have two Folders in the Vault 'Folder A' & 'Folder B'.
You need separate folder cards for both.
What you need to do is create a Folder card for 'Folder A' and Save the card inside the same folder.
Do the same for 'Folder B'.
Thus folder cards of 'Folder A' & 'Folder B' would be separate & independent of each other.
Thanks & Regards,
R.Vignesh
You could set up a datacard with a tab that appears under a specific condition.
I'm sure Adrian Velazquez had a solution for this in the SW top ten, but i cant remember the specific details.
For a static folder structure you can save a folder data card in each folder.
However, in some situations you need EPDM to be a little more dynamic, and that is when you start working with tabs in the datacard.
On the parent data card you insert tabs, and give each tab a logic name. On each tab you design the folder card you need, and then you introduce a variable to control the tabs. Now, by user selection or by using a template, the value of this variable (the tab names) will decide which of the tabs is displayed. A little more on the topic here. (EPDM Help)
