All of the sudden this assembly model is transparetn. And for some reason the XYZ coordanant arrow at the bottom left are black. What is causing this and how do I fix it? I will also say that when I open a larger assembly that has this assembly inside it everything loads correctly. Its only when I open this alone when it does this.
I got the model to show up but its all in a reverse state. here is a rendered picture before the issue and then the model as it opens now.
