The attached shows what I thought was going to be a pretty simple part to model - it's nothing more than a cylinder cut by a plane. I need to convert this to sheet metal but can't figure out a way to do this. Does anyone have any ideas? Thanks!
Bill,
Insert your bending prior to doing the surface cut, then it should work.
I just noticed when you flatten the part with a surface cut it really gets screwy, remove the surface cut and using the same plane that you did the surface cut insert a sketch with an over size rectangle/square and do a through all cut - then you should have a good part
Like this
See the attached
