Hi.
wierd issue. I use SW 2013 and when I try to do a copy with mates with repeat on all mates, no part is generated.
I check all the repeat checkboxes and press V and Nada.
The reason I want to do so is because I want to add a similar part in the same position only with a different material and then insert it into a new configuration.
can anyone help?
Ben
You need to click OK (green tick mark or right click).
Example - Copying with Mates
Copy with mates in SolidWorks
BTW you can create a configuration in the same part having different material and then in assembly configuration change the part configuration to other configuration.
