Task Schedudler
Question asked by Andrew Wylam on May 16, 2015
Latest reply on May 17, 2015 by Deepak Gupta
Can you re run the same task   I am trying to see if you can run the batch print option
I need 50ish  drawings in a set (not always  all  the drawings in the folder)
this is at the start of the project  Then at a later date i need to re run the print run same drawings  as before
do  i need to re run the task or can i just copy and save  the old task or do i need to reset it up again
or can i save a task then re run it at a later date?
Cant see anything in the help files
Thanks Andrew
