How do I draw this sketch to make a sweep of the component to show the acutal path it will follow?
Do you mean 1 component to follow that path through those 3 positions? It looks like the center component is a different size. At any rate, you can do a sweep with guide curves or a boundary feature. There is a solid sweep, that actually drags a solid through a path. But I haven't had good luck with it, and it's only for cuts. If you wanted to try that, you'd have to do it like a mold.
One thing I just thought of is.....
After you're done positioning your pipes in an assembly, you could add a cut that cuts through all the pipes and then insert a new part and in a 3D sketch environment use the cut surfaces to choose the proper radiuses, then link the radius sketches with a tangent straight line etc... that would be the path you need
Possibly look into composite curve or intersection curve, if you have two 2D sketches that you want to 'merge' into one 3D type path. If I'm understanding your intent well enough. You may need to provide more information concerning your intent or expectations.
