I want to set up some jobs, which has solid mesh, using batch manager in SW plastics. I tried to open the folder 'plate' containing all the jobs i want to run. Although, 'plate' has the sub folders of the various models, i cant see reach them (notice 'plate' doesn't show the + sign to its left, whereas the folder above it shows the + sign). Is it because batch manager works for Shell mesh only and i am trying to open solid mesh? In any case, shouldn't i be able to navigate to the sub-folder?
Nikhil
Hi Nikhil,
You should be able to see all available analysis at the bottom of tree:
First, select Folder > then select specific analysis (under Folder tree) > click Add Analysis > this should appear on top of PM tree:
When you finish to add all analysis, click Start at the bottom of PM tree.
Adi
