3 Replies Latest reply on May 14, 2015 10:56 AM by Deepak Gupta
    Check if excel file is open
    Jonny Levelius
      I am writing a macro that when the button is clicked it sends the custom properties of the particular part or assembly to an excel file and lists the properties horizontally.  It then grabs a new part number associated with that row and copies it the clipboard to be pasted into the SaveAs file dialog box.  Then it saves and closes the excel file.  I have it set up where the excel file doesn't even show up.  I need the macro to first check if the master part excel file is already open.  If it is open it will pop up a msgbox saying it is open by username and then exit sub.  I have found much code to do the file check but I can't get it to work with my macro for some reason.  My issue is that when it runs the check it thinks the file is open already when it isn't.  Does anyone have a good file check with username they can show me?
        • Re: Check if excel file is open
          Deepak Gupta
          What you mean by username? Can you share the codes snippet with username you're trying to use?
              Jonny Levelius
              I was hoping to get a msgbox to pop up saying for example "File is already being used by JLevelius".  This is so if somebody is camping in the file we can let them know that we need to get a part number out of it.  My current code doesn't contain the username part of the code yet.
              Here is my entire code.  I am new to VBA and API so it may be a little crude and contain some redundant calls.
              Option Explicit
              Dim swApp               As SldWorks.SldWorks
              Dim swModel            As SldWorks.ModelDoc2
              Dim longstatus          As Long, longwarnings As Long
              Dim xlApp                  As Excel.Application
              Dim xlWb                   As Excel.Workbook
              Dim xlWbs                 As Excel.Workbooks
              Dim xlPath                 As String
              Dim xlFN                    As String
              Dim PARTdescr         As String
              Dim VERIFYpart        As Integer
              Dim str                       As String
              Dim RET
              On Error Resume Next
              Set swModel = swApp.ActiveDoc
              Set xlApp = Excel.Application
              Set xlWbs = Excel.Workbooks
              Set xlWb = xlApp.Workbooks.Open("C:\Users\jlevelius\Desktop\TEST NUMBERING.xlsm")
              '=========================================CHECK IF FILE IS ALREADY IN USE
              RET = IsWorkBookOpen("C:\Users\jlevelius\Desktop\TEST NUMBERING.xlsm")
                  If RET = True Then
                  MsgBox "File is already being used!" '==========IF IN USE THEN EXIT SUB
                  Exit Sub
              '=========================================CHECK IF CORRECT FILE IS BEING SENT TO GET A PART NUMBER
                  Else
                      str = GetMaterialName(swModel)
                      PARTdescr = swModel.CustomInfo("Description") + ", " + swModel.CustomInfo("Sub-Description") + " | " + str
                      VERIFYpart = MsgBox(PROMPT:="Is this the correct part?" & vbNewLine & PARTdescr, Buttons:=vbYesNo)
                      If VERIFYpart = vbNo Then '===============IF WRONG FILE THEN EXIT SUB
                          Exit Sub
                      ElseIf VERIFYpart = vbYes Then '===========IF CORRECT PART THEN CHECK IF PART OR ASSEMBLY AND SEND TO EXCEL FILE
                          Workbooks.Open ("C:\Users\jlevelius\Desktop\TEST NUMBERING.xlsm")
                          If swModel.GetType = swDocPART Then
                              xlPath = Environ("USERPROFILE") & "\Desktop\"
                              xlFN = "Properties Details" & ".xlsx"
                              If Dir(xlPath & xlFN) <> "" Then
                              Kill xlPath & xlFN
                                  Workbooks("TEST NUMBERING.xlsm").Activate
                                  Workbooks("TEST NUMBERING.xlsm").Sheets("PART").Activate
                                  ActiveWorkbook.Worksheets("PART").Range("A1560").Select
                                  Selection.End(xlDown).Select
                                      ActiveCell.Offset(1, 0).Select
                                          ActiveWorkbook.Worksheets("PART").Range("B" & ActiveCell.Row).Value = swModel.CustomInfo("Description")
                                          ActiveWorkbook.Worksheets("PART").Range("C" & ActiveCell.Row).Value = swModel.CustomInfo("Sub-Description")
                                          ActiveWorkbook.Worksheets("PART").Range("D" & ActiveCell.Row).Value = str
                                          ActiveWorkbook.Worksheets("PART").Range("E" & ActiveCell.Row).Value = swModel.CustomInfo("Job Number")
                                          ActiveWorkbook.Worksheets("PART").Range("F" & ActiveCell.Row).Value = swModel.CustomInfo("Client")
                                          ActiveWorkbook.Worksheets("PART").Range("G" & ActiveCell.Row).Value = swModel.CustomInfo("Location")
                                          ActiveWorkbook.Worksheets("PART").Range("I" & ActiveCell.Row).Value = swModel.CustomInfo("Author")
                                          ActiveWorkbook.Worksheets("PART").Range("J" & ActiveCell.Row).Value = swModel.CustomInfo("Vendor")
                                          ActiveWorkbook.Worksheets("PART").Range("K" & ActiveCell.Row).Value = swModel.CustomInfo("Vendor Part Number")
                                  ActiveCell.Copy
                          ElseIf swModel.GetType = swDocASSEMBLY Then
                              Kill xlPath & xlFN
                                  Workbooks("TEST NUMBERING.xlsm").Sheets("ASSEMBLY").Activate
                                  ActiveWorkbook.Worksheets("ASSEMBLY").Range("A156").Select
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("B" & ActiveCell.Row).Value = swModel.CustomInfo("Description")
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("C" & ActiveCell.Row).Value = swModel.CustomInfo("Sub-Description")
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("D" & ActiveCell.Row).Value = ""
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("E" & ActiveCell.Row).Value = swModel.CustomInfo("Job Number")
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("F" & ActiveCell.Row).Value = swModel.CustomInfo("Client")
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("G" & ActiveCell.Row).Value = swModel.CustomInfo("Location")
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("I" & ActiveCell.Row).Value = swModel.CustomInfo("Author")
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("J" & ActiveCell.Row).Value = swModel.CustomInfo("Vendor")
                                          ActiveWorkbook.Worksheets("ASSEMBLY").Range("K" & ActiveCell.Row).Value = swModel.CustomInfo("Vendor Part Number")
                                  ActiveCell.Copy
                      Workbooks("TEST NUMBERING").Close savechanges:=True
              Function GetMaterialName(ByVal ModelToCheck As SldWorks.ModelDoc) As String
              Dim sMaterialName As String
              Dim StartI As Integer
              Dim LastI As Integer
              GetMaterialName = ""
              sMaterialName = ""
              If ModelToCheck Is Nothing Then
                 Exit Function
              sMaterialName = ModelToCheck.MaterialIdName
              StartI = InStr(sMaterialName, "|")
              LastI = InStrRev(sMaterialName, "|")
              If StartI > 0 And LastI > 0 Then
                 If StartI = LastI Then
                    sMaterialName = Right(sMaterialName, Len(sMaterialName) - StartI)
                    GetMaterialName = sMaterialName
                 Else
                    sMaterialName = Mid(sMaterialName, StartI + 1, LastI - StartI - 1)
              End Function
              Function IsWorkBookOpen(FileName As String)
                  Dim ff As Long, ErrNo As Long
                  ff = FreeFile()
                  Open FileName For Input Lock Read As #ff
                  Close ff
                  ErrNo = Err
                  On Error GoTo 0
                  Select Case ErrNo
                  Case 0:    IsWorkBookOpen = False
                  Case 70:   IsWorkBookOpen = True
                  Case Else: Error ErrNo
                  End Select
              End Function
