Controlling the width of an note in vb.net
Question asked by Chris Johnson on May 13, 2015
Here is a snippet of my code where Im inserting a note into SW. I cannot figure out how to control the max width on the annotation. can someone help me fill in the blanks?
everything else works perfectly but controlling the width eludes me............ by the way im writing this as a standalone exe in vb.net not vba.
   'Connect to SolidWorks
            Dim swApp As Object = CreateObject("sldworks.application")
            Dim swModel As ModelDoc2 = Nothing
            Dim swPart As PartDoc = Nothing
            Dim swDrawing As DrawingDoc = Nothing
            Dim swAssembly As AssemblyDoc = Nothing
            Dim boolstatus As Boolean = False
            Dim longstatus As Integer = 0
            Dim longwarnings As Integer = 0
            Dim myNote As Note = Nothing
            Dim myAnnotation As Annotation = Nothing
            Dim myTextFormat As TextFormat = Nothing
            swApp.visible(True)
            swModel = CType(swApp.ActiveDoc, ModelDoc2)
            If Not swModel Is Nothing Then
                'If model Type is drawing then...Insert Note
                If swModel.GetType = 3 Then
                    myNote = CType(swModel.InsertNote(Notes), Note)
                    myNote.Angle = 0
                    boolstatus = myNote.SetBalloon(0, 2)
                    myAnnotation = CType(myNote.GetAnnotation(), Annotation)
                    longstatus = myAnnotation.SetLeader3(CType(swLeaderStyle_e.swNO_LEADER, Integer), 0, True, False, False, False)
                    boolstatus = myAnnotation.SetPosition(0, 0, 0)
                    boolstatus = myAnnotation.SetTextFormat(0, True, myTextFormat)
                    boolstatus =myAnnotation.Width = 8 * 0.00254
thank you kindly for your help!
chris
