7 Replies Latest reply on Jun 15, 2015 11:57 AM by Matt Tolson
    Dissolve Component Pattern VB
    Matt Tolson
      I am trying to dissolve patterns in the Feature Manager Design Tree through a vb program. I could not find an example in the api on how to do this.  I only found the dissolvecomponentpattern function.  I have the following code currently, but when I dissolve it deletes the assembly.
              swFeat = swModel.FirstFeature
              While Not swFeat Is Nothing
                  Debug.Print(swFeat.Name)
                  If swFeat.Name.Contains("Pattern") Then
                      swFeat.Select(False)
                      swModelDoc = swModel
                      swModelDoc.DissolveComponentPattern()
                  swSubFeat = swFeat.GetFirstSubFeature
                  While Not swSubFeat Is Nothing
                      Debug.Print("    " & swSubFeat.Name)
                      swSubFeat = swSubFeat.GetNextSubFeature
                  End While
                  swFeat = swFeat.GetNextFeature
              End While
        • Re: Dissolve Component Pattern VB
          Keith Rice
          For problems like this, it is best to try to create a separate macro that only dissolves the component pattern, in order to understand how that aspect works. Then you can integrate back into your traverse code. For example, create a new VB.NET macro with the following code, select a component pattern, and run the macro:
          Imports SolidWorks.Interop.sldworks
          Imports SolidWorks.Interop.swconst
          Imports System.Runtime.InteropServices
          Imports System
          Partial Class SolidWorksMacro
              Public Sub main()
                  Dim swModel As ModelDoc2 = swApp.ActiveDoc
                  Dim swAssy As AssemblyDoc = swModel
                  swAssy.DissolveComponentPattern()
              Public swApp As SldWorks
          End Class
          Keith
          SolidWorks API Tutorials
            Matt Tolson
            I have modified my originally posted code with the code below.  I was having two issues.
            1. The first issue was that I had to run this code on each assembly.  If I tried to traverse the top level assembly only, it would not select the component pattern in the feature manager.
            2. The second issue was I needed to filter out certain pattern types.  As seen below I used the "GetTypeName2" function to get the pattern I wanted and then I was successfully able to dissolve the component pattern.
                 Debug.Print(sPadStr + swFeat.Name + " [" + swFeat.GetTypeName2 + "]")
                 b = False
                 If swFeat.GetTypeName2.Contains("HolePattern") Or swFeat.GetTypeName2.Contains("LPattern") Then
                      b = swFeat.Select2(False, 0)
                      If b = True Then
                 If b = False Then
             End While
