My assembly is to small. I think the scale is wrong between the layout sketch and the actual assembly. Can this be rectified?
As you can see in the photo below, the assembly is at the X,Y and Z origin.
If you have a sketch that extends out far, even if the sketch is hidden, the layout grid will show large enough to consume the sketch. So make sure you don't have a rogue hidden sketch with a really long line or point off in space. Or if you used a scale feature to shrink a part, it doesn't shrink the sketches that were created before the scale.
Can you drag those yellow dots at the corners of the grid to resize it?
