Hello, I am making an imortant research and I wanted to use stress analyse. I watched a lot of videos, but I can not get it to work
Any idea how to fix it, can somebody help if I send him files ?
I also attached a picture of problem
Kevin
Kevin
Well I tried to restrain them fully, but I can not get it to work, if someone could take a look at the solidworks assembly file, I would be super grateful.
Kevin
I looked at your assembly, it hasn't been modeled correctly. First off, lose the screws & nuts, they don't apply to the FEA. Use split surfaces if you really want to capture the restraint of the 'bolted' connection. Second, design the bracket that fits on the hub 'below' correctly to match the curve or however it is actually attached.
Firstly, your assembly is not fully restrained so I doubt your component contacts are correct/accurate.
Secondarily, you have only global bonded contact set up so I doubt your model is set up accurately in simulation.
I can't tell if your boundary conditions are correct - that's up to you. However, you will have to at least check for interference in the assembly mode and correct those errors before you can begin to mesh the part.
