3 Replies Latest reply on May 14, 2015 9:45 AM by Adam Hoffman
    How to export material property to excel
    Jonny Levelius
      I am writing a long macro that lists the current part/assembly information (Description, Material, Job Number, Client, Location, etc.)  in order horizontally onto an excel spreadsheet.  When I click the button SolidWorks sends this information to the master part numbering excel spreadsheet.  It grabs the next available row and assigns it a new part number.  I can do all this but I can't get the material custom property to show up in the spreadsheet.  What I want it to say, for example, is "AISI 304" but instead it says "SW-Material@Part1.sldprt".  How do you call that custom property and set it equal to a cell in Excel?
        • Re: How to export material property to excel
          Adam Hoffman
          Here is what I use. I don't know how your material library is structured but this works for me.
          Dim str As String
          Set swApp = _
          Application.SldWorks
          If swApp.GetDocumentCount() = 0 Then Exit Sub
          Set swModel = swApp.ActiveDoc
          If Not swModel.GetType() = swDocumentTypes_e.swDocPART Then Exit Sub
          str = ""
          str = GetMaterialName(swModel)
          MsgBox ("The Name Of The Material Is: " + str)
          Function GetMaterialName(ByVal ModelToCheck As SldWorks.ModelDoc) As String
          Dim sMaterialName As String
          Dim StartI As Integer
          Dim LastI As Integer
          GetMaterialName = ""
          sMaterialName = ""
          If ModelToCheck Is Nothing Then
             Exit Function
          sMaterialName = ModelToCheck.MaterialIdName
          StartI = InStr(sMaterialName, "|")
          LastI = InStrRev(sMaterialName, "|")
          If StartI > 0 And LastI > 0 Then
             If StartI = LastI Then
                sMaterialName = Right(sMaterialName, Len(sMaterialName) - StartI)
                GetMaterialName = sMaterialName
             Else
                sMaterialName = Mid(sMaterialName, StartI + 1, LastI - StartI - 1)
          End Function
