hi guys,
Can someone tell me what i am doing wrong? The part only has a roller/slider and it always gives errors... Also when i use a fixed geometry as fixture sw gives me a result.
The part should represent the base of a carjack.
Thanks in advance!
That would certainly work as a first pass. See if you get some reasonable results then try to loosen it up a bit to see what happens. I frequently will fix an edge in one direction while keeping the bottom surface restrained in the normal direction only.
If you restrain the bottom surface completely then you can check your resultants and see what direction the forces are heading and their magnitude.
