21 Replies Latest reply on Jan 31, 2019 2:15 AM by Deepak Gupta
    Save As PDF macro, how to save one or two directories back?
    Shaun Jalbert
      I found a macro online for performing a "save as PDF", but it saves the file under the current working directory. The way our file structure is set up, we have a folder named "PDF" typically one to two directories back. Is there a way to manipulate the existing code so it drops the files under the correct directory?
      Here's the existing code:
          Set swModel = swApp.ActiveDoc
          ' Strip off SolidWorks drawing file extension (.slddrw)
          ' and add DXF file extension (.dxf)
          sPathName = swModel.GetPathName
          sPathName = Left(sPathName, Len(sPathName) - 6)
          sPathName = sPathName + "pdf"
          ' Show current settings
          Debug.Print "DxfMapping             = " & swApp.GetUserPreferenceToggle(swDxfMapping)
          Debug.Print "DXFDontShowMap         = " & swApp.GetUserPreferenceToggle(swDXFDontShowMap)
          Debug.Print "DxfVersion             = " & swApp.GetUserPreferenceIntegerValue(swDxfVersion)
          Debug.Print "DxfOutputFonts         = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputFonts)
          Debug.Print "DxfMappingFileIndex    = " & swApp.GetUserPreferenceIntegerValue(swDxfMappingFileIndex)
          Debug.Print "DxfOutputLineStyles    = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputLineStyles)
          Debug.Print "DxfOutputNoScale       = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputNoScale)
          Debug.Print "DxfMappingFiles        = " & swApp.GetUserPreferenceStringListValue(swDxfMappingFiles)
          Debug.Print "DxfOutputScaleFactor   = " & swApp.GetUserPreferenceDoubleValue(swDxfOutputScaleFactor)
          Debug.Print ""
          ' Turn off showing of map
          bShowMap = swApp.GetUserPreferenceToggle(swDXFDontShowMap)
          Debug.Print "bShowMap = " & bShowMap
          swApp.SetUserPreferenceToggle swDXFDontShowMap, False
          bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
          Beep
          If bRet = False Then
              nRetval = swApp.SendMsgToUser2("Problems saving file.", swMbWarning, swMbOk)
          ' Restore old setting
          swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
        • Re: Save As PDF macro, how to save one or two directories back?
          Deepak Gupta
          Replace these lines
          With
               Dim sFileName As String
              sFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
              sFileName = Left(sFileName, InStrRev(sFileName, ".") - 1)
              sPathName = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "PDF\") + 3)
              sPathName = sPathName & sFileName & ".PDF"
            Keith Rice
            This will save the the current model with a new extension up a certain number of directories from the current model directory. The new extension and number of directories above are specified in the constants at top.
            Const DIR_ABOVE As Integer = 2
            Const NEW_EXTENSION As String = "PDF"
                ' Create new file name
                Dim strModelPath As String
                Dim strSavePath As String
                Dim strFileName As String
                Dim vSplit As Variant
                strModelPath = swModel.GetPathName
                strFileName = Right(strModelPath, Len(strModelPath) - InStrRev(strModelPath, "\"))
                vSplit = Split(strFileName, ".")
                strFileName = vSplit(0) & "." & NEW_EXTENSION
                ' Create new directory
                vSplit = Split(strModelPath, "\")
                Dim i As Integer
                For i = 0 To UBound(vSplit) - DIR_ABOVE - 1
                    strSavePath = strSavePath & vSplit(i) & "\"
                Next i
                strSavePath = strSavePath & strFileName
                Debug.Print "Original path: " & strModelPath
                Debug.Print "New save path: " & strSavePath
                ' Save
                bRet = swModel.Extension.SaveAs(strSavePath, swSaveAsCurrentVersion, _
                    swSaveAsOptions_Silent, Nothing, Empty, Empty)
                If bRet = False Then swApp.SendMsgToUser "Problems saving file."
            Keith
            SolidWorks API Training
                Shaun Jalbert
                Thanks for reply Keith, I didn't try this code, because it sounds like it only saves the file "x" number of directories back.
                I need it to go back "x" number of directories until it finds the folder named "04 PDFs" and then saves the PDF under that directory.
                    Ivana Kolin
                    then change this piece of code
                    1.     For i = 0 To UBound(vSplit)  - 1
                    2.         strSavePath = strSavePath & vSplit(i) & "\"
                    3.         If dir(strSavePath & "04 PDFs", vbDirectory) <> "" then
                    4.        strSavePath = strSavePath & "04 PDFs &"\"
                    5.         exit for
                    6.         end if
                    7.     Next i
                        Shaun Jalbert
                        Hi Ivana:
                        Thanks for the suggestion. I swapped the code you recommended but still no cigar, but it was closer.
                        The file ended up saving to:
                        C:\EPDM_Vault\Projects\101046\01 SolidWorks\
                        But, I need it to go here
                        C:\EPDM_Vault\Projects\101046\04 PDFs\
                        Any more suggestions?
                        ' Preconditions: Drawing file is open.
                        ' Postconditions: DXF file is generated, overwriting any existing file.
                        Option Explicit
                            Dim sPathName               As String
                            Dim nErrors                 As Long
                            Dim nWarnings               As Long
                            Dim nRetval                 As Long
                            Dim bShowMap                As Boolean
                            Dim bRet                    As Boolean
                                Dim i As Integer
                                    If Dir(strSavePath & "04 PDFs") <> "" Then
                            strSavePath = strSavePath & "04 PDFs &" \ ""
                            Exit For
                                Next i
                                ' Save
                            Ivana Kolin
                            this is wrong, I am typing on iPad, so I can't check syntax
                            it has to be : strSavePath = strSavePath & "04 PDFs\"
                                Shaun Jalbert
                                I fixed that and still no go.
                                It looks like it's going back up the folders until it can see the directory "04 PDFs\",
                                but then dumps the file under the last working directory "01 SoldWorks\" instead of then dumping it in "04 PDFs\"
                                But I don't know any better...
                                Any other suggestions?
                                    Jim Sculley
                                    If you can, consider switching from VBA to VB.NET or C#.  You have much more powerful APIs at your disposal that can eliminate all of the ugly hacking and slashing of strings:
                                                ModelDoc2 mDoc = swApp.ActiveDoc as ModelDoc2;
                                                string filePath = mDoc.GetPathName();
                                                string filenameWithoutExtension = Path.GetFileNameWithoutExtension(filePath);
                                                DirectoryInfo parentDirInfo = new DirectoryInfo(filePath);
                                                while (parentDirInfo != null && !parentDirInfo.Name.Equals("04 PDFs"))
                                                    parentDirInfo = parentDirInfo.Parent;
                                                if (parentDirInfo == null)
                                                    MessageBox.Show("No parent PDF directory found");
                                                    return;
                                                string newFileName = parentDirInfo.FullName + Path.DirectorySeparatorChar + filenameWithoutExtension + ".pdf";
                                                ExportPdfData exportData = swApp.GetExportFileData((int)swExportDataFileType_e.swExportPdfData) as ExportPdfData;
                                                exportData.ExportAs3D = false;
                                                exportData.SetSheets((int)swExportDataSheetsToExport_e.swExportData_ExportAllSheets, null);
                                                int errors = 0;
                                                int warnings = 0;
                                                ModelDocExtension mDocExt = mDoc.Extension;
                                                mDocExt.SaveAs(newFileName, (int)swSaveAsVersion_e.swSaveAsCurrentVersion, 0, exportData, ref errors, ref warnings);
                                                if (errors != 0)
                                                    MessageBox.Show("Errors saving PDF: " + errors);
                                                if (warnings != 0)
                                                    MessageBox.Show("Warnings saving PDF: " + warnings);
                              Keith Rice
                              This will find a folder called FOLDER_NAME in one of the parent directories, starting with the root directory and working forward.
                              Const FOLDER_NAME As String = "04 PDFs"
                                  If FOLDER_NAME = Empty Then Exit Sub
                                  Dim strSaveFolder As String
                                  If swModel.GetPathName = Empty Then
                                      swApp.SendMsgToUser "Please save model."
                                      Exit Sub
                                  strFileName = Right(strModelPath, _
                                  Dim intDirAbove As Integer
                                  Dim i As Integer
                                  Dim bFound As Boolean
                                  bFound = False
                                  For i = 0 To UBound(vSplit) - intDirAbove
                                      strSaveFolder = strSaveFolder & vSplit(i) & "\"
                                      If Dir(strSaveFolder & FOLDER_NAME, vbDirectory) <> Empty Then
                                          bFound = True
                                          Exit For
                                  Next i
                                  If bFound = False Then
                                      swApp.SendMsgToUser "Failed to find correct folder."
                                      Exit Sub
                                  strSavePath = strSaveFolder & FOLDER_NAME & "\" & strFileName
                                  ' Save
                              Keith
                              SolidWorks API Tutorials
