Hi, I am interested in simulating a threaded seam that has been sealed with epoxy. This system needs to survive submersion post drop test and we are trying to decide if our standard epoxy is sufficient or if going to a more flexible sealant will do the job for us. In other simulation packages I was able to do this using beam elements generated between two surfaces to be sealed and then looking at the shear stresses generated but I haven't been able to figure out a method to do this in Solidworks yet. Any suggestions?
Ben
why not just bond the 2 parts together and look at the shear stress between them?
or model something in between them if you need the compliance/material props
solidworks won't let you create a beam there because the gap would be too small
