It seems that after several years of using Solidworks, still I need some advice on assembly configuration.
I need an assembly with several configuration. Later this assembly will be used as a sub assembly with different configurations in another assembly.
I've tried 2 methods and I'm facing some troubles.
First Method I used:(test1.SLDASM & Assem1.SLDASM)
I created the assembly and added several global variables, added two configuration and changed the variables for each configuration.
Result : The assembly works perfectly and all configurations show as they're supposed to (when opened as a stand alone assembly)
Problem: When two instances of this assembly is used in another assembly, I can't have separate configurations for each instance.
I have to keep the same configuration for all instances.
Second Method I used:(test2.SLDASM & Assem2.SLDASM)
I created the assembly and added several global variables, added a design table and configured global variables in the design table.
Problem: When two instances of this assembly is used in another assembly, changing the configuration of one instance, changes the configuration of all instances.
How can I use this assemblies as a sub-assembly with different configurations?
Any kind of help/advice is much appreciated.
The behavior you're seeing is correct. Please see Solution Id: S-09810 in SOLIDWORKS Knowledge base for explanation.
Further vote for SPR #: 333561
