0 Replies Latest reply on May 10, 2015 11:05 PM by Yong Ning
    How to travese the point in view?
    Yong Ning
      This point in  a.sldasm→a.sldprt→sketch1→point1
      → Point1@Sketch1@a-1@Drawing View1/Part1-3@a
      record macro code is
      boolstatus = Part.Extension.SelectByID2("Point1@Sketch1@a-1@Drawing View1/Part1-3@a", "EXTSKETCHPOINT", -0.035, -0.018, 0, False, 0, Nothing, 0)
      Help me
      How to traverse the point in view →  For example Fig. select point.
      my method is
      Private Sub ll3()
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
            Set SwApp = Application.SldWorks
            Set SwModel = SwApp.ActiveDoc
         Dim SwSelMgr As SelectionMgr
            Set SwSelMgr = SwModel.SelectionManager
         Dim SwDraw As DrawingDoc, SwView As View
            Set SwDraw = SwModel
            Set SwView = SwSelMgr.GetSelectedObject5(1)
            'Debug.Print SwView.GetName2
         Dim SwAssy As AssemblyDoc, oSwModel As ModelDoc2
            Set SwAssy = SwView.ReferencedDocument
            Debug.Print SwAssy.GetTitle,
            'Stop
         Dim vComp, SwComp As IComponent2
            vComp = SwAssy.GetComponents(True)
            'Set SwComp = vComp(2)
            'Stop
            'Set SwComp = vComp(0)
            'Stop
            Set oSwModel = vComp(0).GetModelDoc
            Debug.Print oSwModel.GetTitle
            'Stop
         Dim SwFeat As IFeature
            'Set SwFeat = SwDraw.FeatureByName("Sketch1@a@Drawing View1/Part1@a")
            Set SwFeat = oSwModel.FeatureByName("Sketch1")
            SwFeat.Select True
            'Stop
         Dim SwSketch As Sketch, SwPt As ISketchPoint, vPt, Pt As ISketchPoint
            Set SwSketch = SwFeat.GetSpecificFeature
            vPt = SwSketch.GetSketchPoints
            For ii = 0 To UBound(vPt)
               Set SwPt = vPt(ii)
               If SwPt.Type = 1 Then
                  Set Pt = SwDraw.CreatePoint2(SwPt.X, SwPt.Y, 0)
                  Stop
            Next ii
            Stop
      Private Sub ll4()
         Dim SwPt As ISketchPoint, PtArr(2) As Double
            Set SwPt = SwSelMgr.GetSelectedObject5(1)
            With SwPt
               PtArr(0) = .X
               PtArr(1) = .Y
            End With
         Dim SwMathUtil As MathUtility
            Set SwMathUtil = SwApp.GetMathUtility
         Dim SwMathPt As IMathPoint
            Set SwMathPt = SwMathUtil.CreatePoint(PtArr)
            Set SwDraw = SwApp.ActivateDoc("t.SldDrw")
            Debug.Print SwDraw.GetPathName
            Set SwView = SwDraw.GetFirstView
            Set SwView = SwView.GetNextView
         Dim SwViewXForm As IMathTransform
            Set SwViewXForm = SwView.ModelToViewTransform
         Dim SwViewPt As IMathPoint
            Set SwViewPt = SwMathPt.MultiplyTransform(SwViewXForm)
         Dim tmp, SwNote As INote
            With SwViewPt
              'Set Pt = SwDraw.CreatePoint2(.ArrayData(0), .ArrayData(1), 0)
              tmp = SwModel.Extension.SelectByID2("", "FACE", .ArrayData(0), .ArrayData(1), 0, False, 0, Nothing, 0)
              Set SwNote = SwDraw.InsertStackedBalloon(1, 1, 1, "", 0, "")
              xx = .ArrayData(0) * 1000
              yy = .ArrayData(1) * 1000
            End With
            Stop
