Bolt Connector Issues
Question asked by Mike Armstrong on May 9, 2015
Latest reply on May 13, 2015 by Jared Conway
I have modelled a clamp which has been designed to resist bending stresses in a flange joint during installation. The clamp has been assessed in a separate analysis and is structurally ok. The issue I have is that the M39 bolts are failing. I have tried to apply just the pre-load on the clamp but the FOS achieved is only 0.5, which seems strange because I am only loading the bolts to approximately 50% proof load.
The pipe is HDPE and with custom input material data.
I have added a No Penetration contact with a 0.2 friction factor, between the clamp and pipe and also restrained the ends of the pipeline with a fixed restraint. I have researched extensively and ran multiple analyses and nothing seems to work.
The clamp deforms when the bolts are pre-tensioned, which is exactly what will happen, but I am unsure if this is causing large bending moments in the bolts which will not occur in a real life situation.
I have attached my model for checking if anyone has time to take a look.
Mike
