I created an assembly.
For some reason, one particular part (right gear in attached image) is causing a problem. When I close/reopen SW 2014, some of the features of the part disappear. It is almost as if the gear is returning to its original default state before I edited it.
Oddly, another part that is also a gear is not having this problem.
I tried copying the problematic gear and pasting in that copy, but the problem remains.
I checked if the problematic files were read-only in the part's file property window, and they are not.
I attached the assembly file and parts.zip.
The problematic parts are:
G2-SpurGear
G3-SpurGear
Thanks! Any help is appreciated!
How do I fix this? Please help!
Thanks.
Dan
Check the external references. Make sure you do not have duplicates (similar named files saved in multiple locations, used by different subassemblies).
