i have a user who is trying to print an assembly file from
his harddrive and each time he tries SW crashes. using SW07
SP2.2 ona P4 3.0Ghz machine. he can print just fine when it's
adrawing or part, but the assembly has trouble for some reason.
the only thing i noticed when he opened the file is that a messagecame up saying "the following items will be converted uponsaving", otherwise the file opens normally.
Please give some detail on the size and complexity of the assembly drawing. How much memory is on his computer, etc? Do you have the 3Gb switch set?
He may be maxing out system resources. Assembly drawings can be the most data intensive task you can do with SolidWorks.
When are you crashing out? While printing or when opening up the file? More details please.... :-)
Regards,
