JWJames Ward05/05/2015
I am setting up standard drawing sheet templates for my workplace. We usually create multi-sheet drawings for manufacture. I have used the custom properties to build a set of changeable properties, but on some sheets I need the value of the property to be different i.e the DWG number.
At the moment the change of properties is applied to every sheet within the multi-sheet drawing for example:
sheet 1 needs to be labelled DWG LP2107-XX-01
sheet 2 needs to be labelled DWG LP2107-XX-02
.. but using the custom properties they are both set to either 01 or 02 and I cannot have both.
Is it possible to have different values for the property without editing the sheet format for each individual sheet?
James.
