2 Replies Latest reply on May 6, 2015 6:55 AM by Manikandan Babu
    how to measure the total routing length through API in solidworks 2014
    Manikandan Babu
      Hi all,
      Precondition
      Selecting the routing assembly in top level assembly
      Postcondition
      To measure the total length of all routesegment.
      Option Explicit
      Dim swmodel As SldWorks.ModelDoc2
      Dim swsel As SldWorks.SelectionMgr
      Dim swcomp As SldWorks.Component2
      Dim swassy As SldWorks.AssemblyDoc
      Dim rtRouteManager As SWRoutingLib.RouteManager
      Dim rtRouteProperty As SWRoutingLib.ElectricalRouteProperty
      Dim sketch As SldWorks.sketch
      Dim skSegments As Variant
      Dim skSegment As SldWorks.SketchSegment
      Dim i As Integer
      Set swmodel = swApp.ActiveDoc
      Set swsel = swmodel.SelectionManager
      Set swcomp = swsel.GetSelectedObject6(1, -1)
      Set swassy = swcomp.GetModelDoc2
      Set rtRouteManager = swassy.GetRouteManager
      rtRouteManager.Editroute
      I have tried upto somelevel but I could not move further,please help me to resolve this.
      Thanks in advance
      Manikandan.B
        • Re: how to measure the total routing length through API in solidworks 2014
          Yuvaraj Sakthivel
          Dear Sir,
          After Edit route , get sketches and select all the sketches and by using Measure tool, we can get total length.
          Kindly verify below code and let me know
          Option Explicit
          Dim i As Integer
          Dim swSktMgr As SldWorks.SketchManager
          Dim swMeasure As SldWorks.Measure
          rtRouteManager.EditRoute
          Set swSktMgr = swmodel.SketchManager
          Set sketch = swSktMgr.ActiveSketch
          skSegments = sketch.GetSketchSegments
          For i = 0 To UBound(skSegments)
          Set skSegment = skSegments(i)
          skSegment.Select4 True, Nothing
          Next i
          Set swMeasure = swmodel.Extension.CreateMeasure
          swMeasure.Calculate Nothing
          Dim swTotal As Double
          swTotal = swMeasure.TotalLength
          swmodel.ClearSelection2 True
          swmodel.ForceRebuild3 True
          swassy.EditAssembly
          MsgBox "Total Length in mm = " & swTotal * 1000
          Regards,
          Yuvaraj S
