I need to make a simple conveyor belt.How to rotate a cylinder 360 degree around it's axis?
I'm not sure if this is what you are asking, but to create a revolved cylinder you would draw the axis and one half of the cylinder profile, then use the Revolved Boss/Base feature to revolve it 360 degrees.
thanks.this is also helpful.
Are you looking to animate it?
yes.as i think it can be do by Mate command.
