Hi all,
I have a problem set up as shown in the fig.1. The goal is to investigate small container surface dryness through air flow over it.The air flows over the bottom surface of the small container due to suction from the vacuum pump. The bottom surface of the container has small amount of water (10ul). I want to investigate the dryness of this surface as the air flows over it. I have modelled the air flow as shown in the fig.2. but having trouble how to set up water condition on the surface and determine corresponding evaporation/dryness? Any suggestions to solve this? Thank you.
Izaz
fig 01 fig 02
there is no way to simulate the water at the bottom as a "free surface" of water
similarly there is no way to estimate the evaporation (phase change)
if your analysis is setup the way it should be, your best bet is to infer what may happen to the air based on temperature and pressure...etc.
