I draw a simple semi circle on two planes with which I want to connect with a lofted sheet metal feature. Ok, I want to incorporate a number of bends on the semi circle, done. However, my outside diameter is incorrect. Go back into the feature to change the reference point from the radius of bend to the flat of the facet....wait...what! No reference point?! Am I overlooking something?
I don't think this is really what you are after, but if you click the "reverse direction" box in the sheet metal parameters then it will toggle whether the reference sketch is on the inside or outside diameter of the part. However I think what you are really asking is if you can change the bends so that the sketch runs tangent to the flats rather than tangent to the bends. I don't see a way to do that, you might need to manually adjust the radius of the sketch to compensate.
