17 Replies Latest reply on May 4, 2015 11:47 AM by Attilio Colangelo
    Has anyone thought of a good way to export free body forces from simulation into excel?
    Vishal Pal
      I've been trying to write a code to get SolidWorks to take the free body forces from simulation and export them to excel. There is a way in simulation to export the free body forces off of a single face but it would be a lot more helpful if I could export the data off multiple faces at once.
        • Re: Has anyone thought of a good way to export free body forces from simulation into excel?
          Jared Conway
          what is the use case?
          what is the workflow that you desire?
            Attilio Colangelo
            There is a CSV export option at the bottom of the Results---> List Result Force  property manager.  It only seems to export one entity at a time so it may not be exactly what you need.
            A more powerful method would be to use the API,  However, there is a learning curve if you haven't used it before. It is worth the investment if you frequently want to customize results or any aspect of simulation for that matter.
              Vishal Pal
              This is a code that I found off of SolidWorks Tutorial website
              Option Explicit
              Function VerifyLong(SwApp As SldWorks.SldWorks, lExpected As Long, lActual As Long, sMessage As String) As Boolean
                  'This function will compare two long values for equivalence.
                  'If they are different, an error message is reported with {sMessage}
                  'as title, and the function returns false.
                  'If equivalent, the function returns true.
                  VerifyLong = True
                  If lActual <> lExpected Then
                      ErrorMsg SwApp, sMessage & ": Expected = " & CStr(lExpected) & " , Actual = " & CStr(lActual)
                      VerifyLong = False
              End Function
              Function VerifyTolerance(SwApp As SldWorks.SldWorks, dExpected As Double, dActual As Double, dTol As Double, sMessage As String) As Boolean
                  'This function will compare two double values to ensure that the actual
                  'value is within the specified tolerance range
                  'of the expected value.  If the actual is not within the tolerance range,
                  'an error message is reported with {sMessage}
                  'as title, and the function returns false. Otherwise, the function returns
                  'true to indicate equivalence/success.
                  VerifyTolerance = True
                  If (dActual < ((1 - dTol) * dExpected)) Or (dActual > ((1 + dTol) * dExpected)) Then
                      ErrorMsg SwApp, sMessage & ": Expected = " & CStr(dExpected) & " , Actual = " & CStr(dActual) & " , Tolerance = " & CStr(dTol) & " percent"
                      VerifyTolerance = False
              End Function
              Function SelectByPID(Part As SldWorks.ModelDoc2, PIDName As String, PIDCollection As Collection) As Object
                  Dim PID()       As Byte
                  Dim PIDVariant  As Variant
                  Dim PIDString   As String
                  Dim i           As Integer
                  Dim SelObj      As Object
                  'Get the string from the collection
                  PIDString = ""
                  PIDString = PIDCollection.Item(PIDName)
                  'Parse the string into an array
                  PIDVariant = Split(PIDString, ",")
                  ReDim PID(UBound(PIDVariant))
                  'Change to a byte array
                  For i = 0 To (UBound(PIDVariant) - 1)
                      PID(i) = PIDVariant(i)
                  Next i
                  'Select the entity
                  Set SelObj = Part.Extension.GetObjectByPersistReference((PID))
                  Set SelectByPID = SelObj
                  Set SelObj = Nothing
              End Function
              Function PIDInitializer() As Collection
                  Dim PIDCollection As New Collection
                  Dim selection1 As String
                  'Constants
                  selection1 = "35,29,213,113,218,129,72,162,168,88,152,178,27,137,239,153,161,1,0,0,16,1,0,0,120,1,109,80,77,75,195,64,20,156,42,181,181,234,65,40,232,197,163,224,69,239,182,232,197,84,44,20,34,155,30,60,8,33,110,54,98,219,36,18,183,224,69,200,143,232,111,240,230,69,252,7,30,253,79,141,243,92,226,7,184,135,157,125,51,243,102,121,175,215,5,86,1,84,203,138,55,177,106,96,3,105,126,30,105,163,76,18,234,198,23,13,52,5,197,201,243,244,190,216,127,25,190,142,107,116,109,59,210,86,228,105,48,181,131,204,6,243,34,25,198,202,220,135,218,201,107,34,171,80,203,15,91,124,15,30,173,127,51,49,218,58,106,155,212,89,96,139,187,236,246,34,202,226,153,33,189,172,14,60,244,112,141,75,20,200,49,129,129,134,101,29,32,101,61,101,45,90,68,213,226,129,111,69,70,20,75,28,17,35,196,56,162,123,4,143,62,133,49,214,75,166,118,254,243,173,0,31,39,125,31,184,218,237,28,186,57,221,205,134,150,199,192,132,113,115,204,24,94,159,231,214,49,246,88,188,157,246,125,217,143,140,214,149,209,178,88,246,247,103,5,205,178,253,23"
                  selection1 = selection1 & "7,173,119,10,108,150,220,236,47,165,78,254,193,79,249,139,99,22,0,0,0,0,0,0,0,0"
                  selection1 = selection1 & ",Type=1"
                  'Store constants in a collection
                  PIDCollection.Add selection1, "selection1"
                  Dim selection2 As String
                  'Constants
                  selection2 = "35,29,213,113,218,129,72,162,168,88,152,178,27,137,239,153,155,1,0,0,15,1,0,0,120,1,109,80,203,74,195,64,20,61,245,85,45,186,16,10,186,113,41,184,209,189,6,221,152,20,11,133,200,164,136,11,161,196,201,68,108,155,68,198,41,116,83,200,71,248,13,238,220,72,255,160,75,255,169,241,12,211,136,130,179,184,119,238,121,13,119,188,54,176,14,160,90,86,172,236,85,3,123,200,138,59,165,141,154,10,149,14,100,181,58,86,134,53,91,128,217,226,237,248,163,251,217,175,187,51,182,105,12,242,164,19,75,21,77,116,218,77,132,122,25,72,199,109,145,235,8,155,230,30,8,166,38,124,28,42,105,28,180,79,250,58,50,250,57,127,186,137,243,100,172,8,47,171,19,31,23,120,192,45,52,10,12,161,32,97,56,71,200,56,143,56,91,46,38,107,240,202,187,32,98,25,195,222,99,143,145,224,140,234,30,124,234,4,250,216,41,153,218,250,79,199,197,190,46,189,16,184,63,108,157,186,37,93,165,161,233,51,48,101,220,4,99,134,215,231,189,121,142,35,14,243,43,47,108,172,64,187,222,129,93,85,23,89,52,50,65,110,254,252,196,102,185,253,99,2"
                  selection2 = selection2 & "17,160,101,183,4,126,99,117,140,77,251,6,67,218,108,28,0,0,0,0,0,0,0,0"
                  selection2 = selection2 & ",Type=1"
                  PIDCollection.Add selection2, "selection2"
                  Set PIDInitializer = PIDCollection
              End Function
              Function ErrorMsg(SwApp As SldWorks.SldWorks, Message As String)
                  SwApp.SendMsgToUser2 Message, 0, 0
                  SwApp.RecordLine "'*** WARNING - General"
                  SwApp.RecordLine "'*** " & Message
                  SwApp.RecordLine ""
              End Function
                  Dim SwApp As SldWorks.SldWorks
                  Dim Part As ModelDoc2
                  Dim COSMOSWORKS As CosmosWorksLib.COSMOSWORKS, CWAddinCallBack As CosmosWorksLib.CWAddinCallBack, ActDoc As CosmosWorksLib.CWModelDoc
                  Dim StudyMngr As CosmosWorksLib.CWStudyManager, Study As CosmosWorksLib.CWStudy, CWMesh As CosmosWorksLib.CWMesh
                  Dim StudyOptions As Object, CWFeatObj As CosmosWorksLib.CWResults, ActDocExt As SldWorks.ModelDocExtension
                  Dim sModelName As String, sStudyName As String
                  Dim sStudyConfig As String
                  Dim longstatus As Long, longwarnings As Long, errCode As Long
                  Dim el As Double, el_hold As Double
                  Dim tl As Double, tl_hold As Double
                  Dim UResMax As Double, Tol1 As Double
                  Dim bStudyFound As Boolean
                  Dim DispArray1 As Variant, DispArray2 As Variant, Force As Variant
                  Dim iMeshUnit As Long, iSolverType As Long, iNumberOfStudies As Long
                  Dim ix As Long, iStudyType As Long
                  sModelName = "C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\samples\tutorial\api\remoteload.sldprt"        'Model name
                  'SolidWorks configuration that study is active under (Blank "" = use default)
                  sStudyConfig = ""
                  sStudyName = "Study 1"                  'Study name
                  iSolverType = swsSolverTypeFFEPlus 'Solver type
                  Set PIDCollection = PIDInitializer()
                  Set SwApp = Application.SldWorks
                  If SwApp Is Nothing Then Exit Sub
                  Set Part = SwApp.OpenDoc6(sModelName, swDocPART, 1, "", longstatus, longwarnings)
                  If Part Is Nothing Then ErrorMsg SwApp, "Failed to open: " & sModelName: GoTo Lastline
                  Set CWAddinCallBack = SwApp.GetAddInObject("SldWorks.Simulation")
                  If CWAddinCallBack Is Nothing Then ErrorMsg SwApp, "CWAddinCallBack object not found": GoTo Lastline
                  Set COSMOSWORKS = CWAddinCallBack.COSMOSWORKS
                  If COSMOSWORKS Is Nothing Then ErrorMsg SwApp, "COSMOSWORKS object not found": GoTo Lastline
                  'Get active document
                  Set ActDoc = COSMOSWORKS.ActiveDoc
                  If ActDoc Is Nothing Then ErrorMsg SwApp, "No active document": GoTo Lastline
                  'If needed, rebuild the model
                  Set ActDocExt = Part.Extension
                  If (ActDocExt.NeedsRebuild = True) Then
                      Part.ForceRebuild3 (False)
                  'If needed, change the SolidWorks configuration to activate the study
                  If sStudyConfig <> "" Then
                      Part.ShowConfiguration2 (sStudyConfig)
                  Set StudyMngr = ActDoc.StudyManager
                  If StudyMngr Is Nothing Then ErrorMsg SwApp, "StudyMngr object not there": GoTo Lastline
                  'Find the study
                  bStudyFound = False
                  iNumberOfStudies = StudyMngr.StudyCount
                  For ix = 0 To iNumberOfStudies
                      StudyMngr.ActiveStudy = ix
                      Set Study = StudyMngr.GetStudy(ix)
                      If Study Is Nothing Then ErrorMsg SwApp, "Failed to get study number: " & ix: GoTo Lastline
                      If UCase(Study.Name) = UCase(sStudyName) Then
                          bStudyFound = True
                          Exit For
                  Next
                  If bStudyFound = False Then
                      ErrorMsg SwApp, "Failed to find study named: " & sStudyName: GoTo Lastline
                  'Get analysis type
                  iStudyType = Study.AnalysisType
                  If iStudyType = swsAnalysisStudyTypeStatic Then
                      Set StudyOptions = Study.StaticStudyOptions
                  ElseIf iStudyType = swsAnalysisStudyTypeThermal Then
                      Set StudyOptions = Study.ThermalStudyOptions
                  ElseIf iStudyType = swsAnalysisStudyTypeFrequency Then
                      Set StudyOptions = Study.FrequencyStudyOptions
                  ElseIf iStudyType = swsAnalysisStudyTypeBuckling Then
                      Set StudyOptions = Study.BucklingStudyOptions
                  ElseIf iStudyType = swsAnalysisStudyTypeNonlinear Then
                      Set StudyOptions = Study.NonLinearStudyOptions
                  Else
                      ErrorMsg SwApp, "StudyOptions for this analysis type is not yet supported": GoTo Lastline
                  If StudyOptions Is Nothing Then ErrorMsg SwApp, "Failed to get StudyOptions object": GoTo Lastline
                  'Set solver type
                  StudyOptions.SolverType = iSolverType
                  'Getting results
                  Set CWFeatObj = Study.Results
                  If CWFeatObj Is Nothing Then ErrorMsg SwApp, "Failed to get result object": GoTo Lastline
                  DispArray1 = Array(SelectByPID(Part, "selection1", PIDCollection))  'Face<1>
                  DispArray2 = Array(SelectByPID(Part, "selection2", PIDCollection))  'Vertex moment reference
                  Force = CWFeatObj.GetFreeBodyForcesAndMoments(Nothing, (DispArray2), (DispArray1), 0, errCode)
                  Debug.Print "Free body forces and moments:"
                  Debug.Print "   Free body force x-components of all selections: " & Force(0)
                  Debug.Print "   Free body force y-components of all selections: " & Force(1)
                  Debug.Print "   Free body force z-components of all selections: " & Force(2)
                  Debug.Print "   Resultant free body force of all selections: " & Force(3)
                  Debug.Print "   Free body moment x-components of all selections: " & Force(4)
                  Debug.Print "   Free body moment y-components of all selections: " & Force(5)
                  Debug.Print "   Free body moment z-components of all selections: " & Force(6)
                  Debug.Print "   Resultant free body moment of all selections: " & Force(7)
                  Debug.Print "   Free body force x-components of entire model: " & Force(8)
                  Debug.Print "   Free body force y-components of entire model: " & Force(9)
                  Debug.Print "   Free body force z-components of entire model: " & Force(10)
                  Debug.Print "   Resultant free body force of entire model: " & Force(11)
                  Debug.Print "   Free body moment x-components of entire model: " & Force(12)
                  Debug.Print "   Free body moment y-components of entire model: " & Force(13)
                  Debug.Print "   Free body moment z-components of entire model: " & Force(14)
                  Debug.Print "   Resultant free body moment of entire model: " & Force(15)
                  If errCode <> 0 Then ErrorMsg SwApp, "Failed to get free body force result": GoTo Lastline
                  UResMax = 100
                  Tol1 = 0.1
                  'Check resultant free body force
                  If VerifyTolerance(SwApp, UResMax, CDbl(Force(3)), Tol1, " Resultant free body force of all selections is beyond tolerance") = False Then GoTo Lastline
              Lastline:
              It spits out a bunch of values at the end. However I do not know what units these values are in or am I able to recreate them manually
