Hello, how do we create the above items in SolidWorks? Do we have to make small individual parts (e.g. ball) and assembly the parts together to make ball bearing/ball bearing rails? Thanks.
It depends on the level of detail you want. If you are using the BBs in an assembly, you'd probably just model the outline of the assembled bearing as a single part. If you are a ball bearing designer, you'll model each component of the ball bearing with sufficient detail to manufacture it.
