LWLeon Wurr30/04/2015
     I've put together this macro to change the scales on drawings. If a view is selected, it changes the view scale only, if nothing is selected, it changes the sheet scale.
     I created macro buttons in the "View Layout" tab and added keyboard shortcuts to it:
     Just wanted to share. I'm attaching the macros and the .bmp files of the buttons in this thread in case anyone is interested.
     The idea came when reading this thread:
Dim swApp                       As SldWorks.SldWorks
Dim swModel                     As SldWorks.ModelDoc2
Dim swSelMgr                    As SldWorks.SelectionMgr
Dim swView                      As SldWorks.View
Dim boolstatus                  As Boolean
Dim currentSheet                As Sheet
Dim swDraw                      As SldWorks.DrawingDoc
Dim X                           As Integer
Dim Y                           As Integer
Dim swScale                     As Double
Dim bRet                        As Boolean
    X = 1                                                  'The scale will be set as X:Y
    Y = 1
    Debug.Print "Scale          = " & X & ":" & Y
    swScale = X / Y
    Debug.Print "swScale          = "; swScale
    Set swModel = swApp.ActiveDoc
    Set currentSheet = swModel.GetCurrentSheet
    On Error Resume Next
    Set swView = swSelMgr.GetSelectedObject6(1, -2)
    If Not swView Is Nothing Then
        swView.ScaleDecimal = swScale
        bRet = swDraw.ForceRebuild3(False)
        Else
        boolstatus = currentSheet.SetScale(X, Y, True, False)
    swModel.ClearSelection2 False
    swModel.ForceRebuild3 False
