Are the Design Checker sheet format paths case sensitive?
Question asked by Elisabeth Daley on Apr 29, 2015
Latest reply on Jun 1, 2015 by Elisabeth Daley
I'm trying to set up a Design Checker file to verify that all drawings are using one of a set of sheet formats.  However, every document fails the check, and I've noticed that the only difference between the path that shows up when I use the Learn Checks Wizard is that that path is lowercase, whereas when I use the 'Add' button to put in all the other possibly valid templates is that when I manually add the paths, they include capitalization.  Has anyone had a similar issue, and if not, why aren't my documents passing the checks, when I know I have the same template loaded that I've specified in my Design Checker file?
