4 Replies Latest reply on May 18, 2015 6:46 AM by Dennis Moll
    Creating Drawing Dimensions Causes System.AccessViolationException
    Matthew Elgie
      Hello-
      I have been attempting to automate Sheet Metal drawings for a while. As I get ever closer, I come across more and more difficult problems.
      I am opening up a drawing, and am cycling through each visible edge for each view.
      In the below code I then apply a Dimension when I find two matching orientation edges. This works fine, the problem comes when I try and do this for a batch of drawings. When I loop through the code over multiple drawings I inevitably get the following error:
      An exception of type 'System.AccessViolationException' occurred in PHOEN-IX.dll and wasn't handled before a managed/native boundary
      Additional information: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.a'' <<<<-------------- ERRORS AT THIS LINE
      AT LINES:
      122 & 157
      I can not seem to locate any sort of solution to this problem. I am hoping that there is just a small mistake in my code that will solve the problem, but so far nothing seems to have solved the problem. I have even sprinkled GC.Collects into the code to try and free up all of the memory as I go.
      And help would be greatly appreciated.
      Thanks-
      Code Sample
      Sub Test1(ByRef swthatEdge As sldworks.Edge, ByRef swthatView As sldworks.View)
              GC.Collect()
              Const nTolerance As Double = 0.00000001
             Const nXoffset As Double = 0.01
              Const nYoffset As Double = 0.01
              Dim swthisApp As sldworks.SldWorks
              Dim swthisModel As sldworks.ModelDoc2
              Dim swthisSelMgr As sldworks.SelectionMgr
              Dim swthisEnt As sldworks.Entity
              Dim swCurve As sldworks.Curve
              Dim vCurveParam As Object
              Dim nDummy As Long
              Dim nIdentity As Long
              Dim nTag As Long
              Dim nSense As Long
              Dim swMathUtil As sldworks.MathUtility
              Dim nPtData(2) As Double
              Dim vPtData As Object
              Dim swModelStartPt As sldworks.MathPoint
              Dim swModelEndPt As sldworks.MathPoint
              Dim swViewStartPt As sldworks.MathPoint
              Dim swViewEndPt As sldworks.MathPoint
              Dim swthisView As sldworks.View
              Dim swViewXform As sldworks.MathTransform
              Dim vOutline As Object
              Dim swDispDim As sldworks.DisplayDimension
              Dim nXpos As Double
              Dim nYpos As Double
              Dim bRet2 As Boolean
              Dim bRet3 As Boolean
              swthisApp = CreateObject("SldWorks.Application")
              swthisModel = swthisApp.ActiveDoc
              swthisView = swthatView
              swthisSelMgr = swthisModel.SelectionManager
              swCurve = swthatEdge.GetCurve
              swthisEnt = swthatEdge
              vCurveParam = swthisEnt.GetCurveParams2
              DoubleIntConv.Unpack(vCurveParam(8), nDummy, nIdentity)
              DoubleIntConv.Unpack(vCurveParam(9), nDummy, nTag)
              DoubleIntConv.Unpack(vCurveParam(10), nDummy, nSense)
                 ' Derived quantity
              Debug.Print("Length     = " & swCurve.GetLength2(vCurveParam(6), vCurveParam(7)) * 1000.0# & " mm ")
              Debug.Print("")
              ' Only makes sense for straight edges
              If LINE_TYPE <> nIdentity Then Exit Sub
              swMathUtil = swthisApp.GetMathUtility
              nPtData(0) = vCurveParam(0)
              nPtData(1) = vCurveParam(1)
              nPtData(2) = vCurveParam(2)
              vPtData = nPtData
              swModelStartPt = swMathUtil.CreatePoint(vPtData)
              nPtData(0) = vCurveParam(3)
              nPtData(1) = vCurveParam(4)
              nPtData(2) = vCurveParam(5)
              vPtData = nPtData
              swModelEndPt = swMathUtil.CreatePoint(vPtData)
              ' Start creating drawing of the model
              ' Select regardless
              swthisModel.ClearSelection()
              bRet2 = swthisView.SelectEntity(swthisEnt, True)
              'Debug.Assert(bRet)
              vOutline = swthisView.GetOutline
              swViewXform = swthisView.ModelToViewTransform
              swViewStartPt = swModelStartPt.MultiplyTransform(swViewXform)
              swViewEndPt = swModelEndPt.MultiplyTransform(swViewXform)
                    If Math.Abs(swViewStartPt.ArrayData(0) - swViewEndPt.ArrayData(0)) < nTolerance Then
                  ' Must be vertical
                  'If Not entPreviouseHorEdge Is Nothing Then
                  '    swthisModel.ClearSelection()
                  '    entPreviouseVertEdge = swthisEnt
                  '    GoTo nextone
                  'End If
                  ' Place dimension midway up edge and to the right of view
                  nXpos = vOutline(0) - nXoffset
                  nYpos = Math.Abs((swViewStartPt.ArrayData(1) + swViewEndPt.ArrayData(1)) / 2.0#)
                  'If this is missing then next line fails for unknown reason
                  'swthisModel.ForceRebuild3(False)
                  If Not entPreviouseVertEdge Is Nothing Then
                      GC.Collect()
                      bRet3 = swthisView.SelectEntity(entPreviouseVertEdge, True) '' <<<<-------------- ERRORS AT THIS LINE
                      entPreviouseVertEdge = Nothing
                      swDispDim = swthisModel.AddVerticalDimension2(nXpos, nYpos, 0.0#)
                      swDispDim = Nothing
                      bRet3 = Nothing
                      swthisModel = Nothing
                  Else
                  ' NULL if cannot convert edge in this view
              ElseIf Math.Abs(swViewStartPt.ArrayData(1) - swViewEndPt.ArrayData(1)) < nTolerance Then
                  ' Must be horizontal
                  'If Not entPreviouseVertEdge Is Nothing Then
                  '    entPreviouseHorEdge = swthisEnt
                  '    GoTo nextone
                  'End If
                  ' Place dimension midway across edge and above view
                  nXpos = Math.Abs((swViewStartPt.ArrayData(0) + swViewEndPt.ArrayData(0)) / 2.0#)
                  nYpos = vOutline(3) + nYoffset
                      GC.Collect()
                      bRet3 = swthisView.SelectEntity(entPreviouseHorEdge, True)'' <<<<-------------- ERRORS AT THIS LINE
                      entPreviouseHorEdge = Nothing
                  Else
              Else
                  ' Neither horizontal or vertical
                  ' Place dimension near middle of edge
                  nXpos = Math.Abs((swViewStartPt.ArrayData(0) + swViewEndPt.ArrayData(0)) / 2.0#) + nXoffset
                  nYpos = Math.Abs((swViewStartPt.ArrayData(1) + swViewEndPt.ArrayData(1)) / 2.0#) + nYoffset
                  ' Depends on the orientation of the entity in the drawing view,
                  ' thus, could be NULL
                  ' Create the dimension even if the entity is not
                  ' visible in the drawing view
                  swDispDim = swthisModel.AddDimension2(nXpos, nYpos, 0.0#)
              swDispDim = Nothing
              bRet2 = Nothing
              bRet3 = Nothing
              swCurve = Nothing
              swthisEnt = Nothing
              vCurveParam = Nothing
              swthisApp = Nothing
              swthisView = Nothing
              swthisSelMgr = Nothing
              GC.Collect()
              GC.WaitForFullGCComplete()
