1 Reply Latest reply on May 5, 2015 1:07 PM by Jay Donihoo
    I am new to programming please help me i wrote a program for v block which by giving dimensions designs v block on its own
    Saikiran Srirambhatla
      i attached my program here please correct my program
      Private Sub CommandButton1_Click()
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
      Part.SketchManager.InsertSketch True
      Part.ClearSelection2 True
      Dim skSegment As Object
      Set skSegment = Part.SketchManager.CreateLine(-0.083999, -0.057931, 0#, 0.097241, -0.057931, 0#)
      Set skSegment = Part.SketchManager.CreateLine(0.097241, -0.057931, 0#, 0.097241, 0.048827, 0#)
      Set skSegment = Part.SketchManager.CreateLine(0.097241, 0.048827, 0#, 0.088137, 0.048827, 0#)
      Set skSegment = Part.SketchManager.CreateLine(0.088137, 0.048827, 0#, 0.041793, -0.033931, 0#)
      Set skSegment = Part.SketchManager.CreateLine(0.041793, -0.033931, 0#, -0.020276, -0.033931, 0#)
      Set skSegment = Part.SketchManager.CreateLine(-0.020276, -0.033931, 0#, -0.071586, 0.048827, 0#)
      Set skSegment = Part.SketchManager.CreateLine(-0.071586, 0.048827, 0#, -0.083999, 0.048827, 0#)
      Set skSegment = Part.SketchManager.CreateLine(-0.083999, 0.048827, 0#, -0.083999, -0.057931, 0#)
      Part.SetPickMode
      boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", -0.031034257852077, -5.83444047619048E-02, 0, False, 0, Nothing, 0)
      Dim myDisplayDim As Object
      Set myDisplayDim = Part.AddDimension2(-2.85515172239108E-02, -7.98614902060115E-02, 0)
      Dim myDimension As Object
      Set myDimension = Part.Parameter("D1@Sketch1")
      myDimension.SystemValue = TextBox1.Value / 1000
      boolstatus = Part.Extension.SelectByID2("Point7", "SKETCHPOINT", -7.15856881121243E-02, 4.88272323539345E-02, 0, False, 0, Nothing, 0)
      boolstatus = Part.Extension.SelectByID2("Point4", "SKETCHPOINT", 8.81372922998987E-02, 4.88272323539345E-02, 0, True, 0, Nothing, 0)
      Set myDisplayDim = Part.AddDimension2(7.52465938892025E-02, 5.39403354766828E-02, 0)
      boolstatus = Part.Extension.SelectByID2("D1@Sketch1@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
      Set myDimension = Part.Parameter("D2@Sketch1")
      myDimension.SystemValue = TextBox2.Value / 1000
      boolstatus = Part.Extension.SelectByID2("Line7", "SKETCHSEGMENT", -7.80276122658087E-02, 4.91654896991768E-02, 0, False, 0, Nothing, 0)
      Set myDisplayDim = Part.AddDimension2(-7.77581071437855E-02, 0.066413817508659, 0)
      boolstatus = Part.Extension.SelectByID2("D2@Sketch1@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
      Set myDimension = Part.Parameter("D3@Sketch1")
      myDimension.SystemValue = TextBox3.Value / 1000
      boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 9.09501179352416E-02, 4.95129105965846E-02, 0, False, 0, Nothing, 0)
      Set myDisplayDim = Part.AddDimension2(9.63656239296345E-02, 7.14328158119844E-02, 0)
      Set myDimension = Part.Parameter("D4@Sketch1")
      myDimension.SystemValue = TextBox4.Value / 1000
      boolstatus = Part.Extension.SelectByID2("Line5", "SKETCHSEGMENT", 7.72551305096969E-03, -3.44094342691546E-02, 0, False, 0, Nothing, 0)
      Set myDisplayDim = Part.AddDimension2(0.193302562314296, -4.74999315200947E-02, 0)
      boolstatus = Part.Extension.SelectByID2("D4@Sketch1@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
      Set myDimension = Part.Parameter("D5@Sketch1")
      myDimension.SystemValue = TextBox5.Value / 1000
      boolstatus = Part.Extension.SelectByID2("Line6", "SKETCHSEGMENT", -4.15563589525694E-02, 1.01191123338906E-03, 0, False, 0, Nothing, 0)
      boolstatus = Part.Extension.SelectByID2("Line4", "SKETCHSEGMENT", 5.31572388042322E-02, 5.63208673372084E-03, 0, True, 0, Nothing, 0)
      Part.SketchAddConstraints "sgSAMELENGTH"
      boolstatus = Part.Extension.SelectByID2("Line5", "SKETCHSEGMENT", -6.13501345002576E-03, -3.51794635192099E-02, 0, False, 0, Nothing, 0)
      boolstatus = Part.Extension.SelectByID2("Point8", "SKETCHPOINT", -8.62757014543012E-02, 4.95771926425102E-02, 0, True, 0, Nothing, 0)
      Set myDisplayDim = Part.AddDimension2(-0.130879751958984, 3.79733152360433E-02, 0)
      Set myDimension = Part.Parameter("D6@Sketch1")
      myDimension.SystemValue = TextBox6.Value / 1000
      boolstatus = Part.Extension.SelectByID2("Line8", "SKETCHSEGMENT", -9.00682017060531E-02, -7.45841051721924E-03, 0, False, 0, Nothing, 0)
      Set myDisplayDim = Part.AddDimension2(-0.176311477712246, -1.29817651677683E-03, 0)
      Set myDimension = Part.Parameter("D7@Sketch1")
      myDimension.SystemValue = TextBox7.Value / 1000
      Part.ShowNamedView2 "*Trimetric", 8
      Dim myFeature As Object
      Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 6, 0, TextBox8.Value / 1000, 0.01, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, True, True, True, 0, 0, False)
      Part.SelectionManager.EnableContourSelection = False
        • Re: I am new to programming please help me i wrote a program for v block which by giving dimensions designs v block on its own
          Jay Donihoo
          I think you're not getting responses due to the fact that this is more than likely (almost certainly) a recorded macro from Solidworks. But mostly because you haven't defined what your problem is. How do you expect people to offer free help when you say "fix it please" AKA "do this for me so I don't have to  please."
          The code you provided will draw a vblock every time you run it. Just save a generic vblock.prt  with arbitrary values and edit them later with code.
          I assume that since you are dividing by 1000 that you're using metric values.
          This code will be in your main module.
          Public Part As SldWorks.ModelDoc2
          Public boolstatus As Boolean
          Public longstatus As Long, longwarnings As Long
          Public ModelName As String  ' For filename with extension
          Public Sub_Main()
          ModelName = Part.GetTitle
          End sub
          'Change Dimension Values
          Public Sub Change_Values(ValueToChange As String, SketchWhereLocated As String, TextBox As Double)
          Part.Parameter(ValueToChange & "@" & SketchWhereLocated & "@" & ModelName).SystemValue = (TextBox /1000)
          This code will be your CommandButton1_Click() 'copy and adjust for each dimension you want to change.
          Call change_values(D7, Sketch1, TextBox7)
          All of that replaces that million lines of code that was recorded.
          Let me know if that works.
          Keep in mind I am no programmer by any means so I'm sure there is far better ways of doing this.
          try this link for some more insight on this subject.
          Edit multiple dimensions at once
