Get all start points in a sketch of splines
Question asked by Alec Hearne on Apr 28, 2015
Latest reply on Apr 29, 2015 by Simon Turner
I am trying to get the start points for each spline in a given sketch, and when I run the code below, I get to the "GetCurve" command and get the error "Object variable or With block variable not set." I printed the sketch segment type and got "3", or a spline, which I believe should be compatible with the GetCurve command.
My guess is that the "GetSketchSegments" command doesn't return the correct type of handle to pull curve data, does anyone know the correct way to do this?
Option Explicit
    Dim swApp                    As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swSketch                As SldWorks.Sketch
    Dim bRet                       As Boolean
    Dim vSketchSgArr            As Variant
    Dim vSketchSG               As Variant
    Dim swSketchSg              As SldWorks.SketchSegment
    Dim swCurve                 As Object
    Dim skLength                As Double
    Dim startPt                 As SldWorks.SketchPoint
    Dim nStartParam             As Double
    Dim nEndParam               As Double
    Dim bIsClosed               As Boolean
    Dim bIsPeriodic             As Boolean
    Set swModel = swApp.ActiveDoc
    Set swSketch = swModel.GetActiveSketch2
    vSketchSgArr = swSketch.GetSketchSegments()
    For Each vSketchSG In vSketchSgArr
        Set swSketchSg = vSketchSG
        If swSketchSg.GetType = 3 Then
            swCurve = swSketchSg.GetCurve
            bRet = swCurve.GetEndParams(nStartParam, nEndParam, bIsClosed, bIsPeriodic)
            skLength = swCurve.GetLength2(nStartParam, nEndParam)
            startPt = swCurve.Evaluate(nStartParam)
    Next vSketchSG
