Add component with specific configuration
Question asked by Charles Robin on Apr 29, 2015
Latest reply on May 4, 2015 by Charles Robin
Hi i would like to add a component with a specifique congiration (the string is "configpart" in the code)
But the added part is ever with the last used configiguration.
Anyone know what is wrong in the code?
thank you
' Preconditions: Open
' install_dir\Program Files\SolidWorks\samples\tutorial\toolbox\lens_mount.sldasm
' Postconditions:
' 1. The specified component, camtest.sldprt, and a mate,
'    top_coinc_camtest-1, are added to the assembly.
' 2. Examine the FeatureManager design tree to verify the mate.
' NOTE: Because the models are used elsewhere, do not
' save any changes when closing them.
Option Explicit
Dim swApp As New SldWorks.SldWorks
Dim swModel As ModelDoc2
Dim swDocExt As ModelDocExtension
Dim swAssy As AssemblyDoc
Dim tmpPath As String
Dim tmpObj As SldWorks.ModelDoc2
Dim boolstat As Boolean
Dim strings As Variant
Dim swcomponent As SldWorks.Component2
Dim matefeature As SldWorks.Feature
Dim MateName As String
Dim FirstSelection As String
Dim SecondSelection As String
Dim Alignment As swMateAlign_e
Dim strCompName As String
Dim AssemblyTitle As String
Dim AssemblyName As String
Dim errors As Long
Dim warnings As Long
Dim mateError As Long
Dim Configpart As String
Sub Main()
    Set swModel = swApp.ActiveDoc
    ' Get title of assembly document
    AssemblyTitle = swModel.GetTitle
    ' Split the title into two strings using the period (.) as the delimiter
    strings = Split(AssemblyTitle, ".")
    ' You'll use AssemblyName when mating the component with the assembly
    AssemblyName = strings(0)
    'Debug.Print AssemblyName
    boolstat = True
    Dim strCompModelname As String
    strCompModelname = "Vis Tête cylindrique à 6 Pans Creux.SLDPRT"
    ' Because the component resides in the same folder as the assembly, get
    ' the assembly's path and use it when opening the component
    'tmpPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\"))
    tmpPath = "Z:\Redilec\PLANS\SW\Accessoires\Visserie\"
    ' Open the component
    Configpart = "Vis Tête cylindrique à 6 Pans Creux M5x30"
    Set tmpObj = swApp.OpenDoc6(tmpPath + strCompModelname, swDocPART, 0, Configpart, errors, warnings)
    ' Check to see if the file is read-only or cannot be found; display error
    ' messages if either
    If warnings = swFileLoadWarning_ReadOnly Then
        MsgBox "This file is read-only."
        boolstat = False
    If tmpObj Is Nothing Then
        MsgBox "Cannot locate the file."
        boolstat = False
    'Re-activate the assembly so that you can add the component to it
    Set swModel = swApp.ActivateDoc2(AssemblyTitle, True, errors)
    Set swAssy = swModel
    ' Add the camtest part to the assembly document.
    ' Currently only one option, swAddComponentConfigOptions_e.swAddComponentConfigOptions_CurrentSelectedConfig,
    ' works for adding a part using AddComponent5. The other options, swAddComponentConfigOptions_e.swAddComponentConfigOptions_NewConfigWithAllReferenceModels and
    ' swAddComponentConfigOptions_e.swAddComponentConfigOptions_NewConfigWithAsmStructure, work only for adding assemblies using AddComponent5.
   Set swcomponent = swAssy.AddComponent5(strCompModelname, swAddComponentConfigOptions_CurrentSelectedConfig, "", True, Configpart, -1, -1, -1)
    ' Get the name of the component for the mate
    strCompName = swcomponent.Name2()
    ' Create the name of the mate and the names of the planes to use for the mate
    MateName = "top_coinc_" + strCompName
    FirstSelection = "Plan1@" + strCompName & "@" + AssemblyName
    SecondSelection = "Plan de face@" + AssemblyName
    Set swDocExt = swModel.Extension
    swModel.ClearSelection2 (True)
    ' Select the planes for the mate
    boolstat = swDocExt.SelectByID2(FirstSelection, "PLANE", 0, 0, 0, True, 1, Nothing, swSelectOptionDefault)
    boolstat = swDocExt.SelectByID2(SecondSelection, "PLANE", 0, 0, 0, True, 1, Nothing, swSelectOptionDefault)
    ' Add the mate
    Set matefeature = swAssy.AddMate3(swMateCOINCIDENT, swMateAlignALIGNED, False, 0, 0, 0, 0, 0, 0, 0, 0, False, mateError)
    matefeature.Name = "mate"
    swModel.ViewZoomtofit2
