I am trying to penetrate 2 pipes symmetrically perpendicular on a larger one but the penetrate command is not enabled to be used at that intersection point. is there any solution for that ?
thanks
thanks
Does it work on that point for only one of them ?
Just guessing, did not try it.
Maybe you should move one of them away whilst you do the first one and put it on the correct spot to do the second one after you have finished with the first one.
Or shorten the pipe on one of them so both of them do not intersect while you are executing the penetrate command (It might even not show if they both intersect the same spot) for the one that intersect the line on the bigger pipe,
Hope this makes any sense.
Easiest way to solve this:
1. u need to make some displacement between branches, fe. 0,001mm
2. set penetration for first point
3. set penetration to second point
Effect:
They behave like concentric pipes
