12 Replies Latest reply on Apr 29, 2015 10:19 AM by James Kashuba
    How to remove specific custom properties
    James Kashuba
      Good Morning Folks,
      I am trying to remove several custom properties from a number of files with in a folder. I do not want all the custom props removed only specific ones so the macro would have to be edited by me to fill in the blanks. Could any help me out with this?
      Thank you all,
      Jim
        • Re: How to remove specific custom properties
          Steven Richmond
          Hi James
          The one I use to delete custom properties goes like this
          Option Explicit
              Dim swApp              As SldWorks.SldWorks
              Dim swModel            As SldWorks.ModelDoc2
              Dim swCustPropMgr      As SldWorks.CustomPropertyManager
              Dim strVal              As String
              Dim Value              As String
          Private Sub Start1()
              Set swModel = swApp.ActiveDoc
              If swModel Is Nothing Then MsgBox "A Part or Assembly file must be open", vbExclamation: End
              Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Empty)
          Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
          swCustPropMgr.Delete "Finish"
          MsgBox " Custom Property data updated."
          End
          The " swCustPropMgr.Delete "Finish" " section is the bit where the custom property is removed, so change "Finish" for whatever custom property you have. Copy and paste below for as many properties you want to change. You could then run this through task scheduler to run over a bunch of files located in a folder rather than individually doing it.
          Hope this helps
          Steven
              James Kashuba
              Steven,
              thank you so much! I wish I understood all that the code was doing, but regardless - it works just the way I wanted it to.
              Thanks again and have a great day!
              Jim
                James Kashuba
                Steven,
                The Task Scheduler is not as easy as I thought. I figured I'd set the program (SW), choose the macro, and then choose the folder location that contains all the files that need updating. The Scheduler doesn't seem to provide for a folder location. That being the case, how does the macro know what files to update? Obviously I'm missing something, can you please point out what it is that I'm missing?
                Thanks again
                      James Kashuba
                      Steven,
                      Would you mind using your code injunction with the code that you would have to write to open all files in a given folder to be used in Task Scheduler? I have been trying since early this morning to make this work and it's become clear to me that I'm just wasting my time. I read the tutorial but I need more tutoring. So what I'm asking is can you provide the exact code you would use to do this task in TS, and I'll manipulate the parameters to suite my machine?
                      Thanks again,
                          Steven Richmond
                          James
                          Try running this macro from within Solidworks to bypass Task Schedular as Deepak Gupta recommends in his response.
                          Const strFolderPath As String = "C:\Users\srichmond\Desktop\Test\"
                          Dim strFileName As String
                              strFileName = Dir(strFolderPath & "*.SLDPRT")
                              While strFileName <> ""
                                  Set swModel = swApp.OpenDoc6(strFolderPath & strFileName, _
                                      swDocPART, 1, Empty, Empty, Empty)
                                  swCustPropMgr.Delete "NewPartNo"
                                  swModel.Save3 1, Empty, Empty
                                  swApp.QuitDoc swModel.GetTitle
                                  strFileName = Dir
                              Wend
                              swApp.ExitApp
                          When you change the file location (3rd line down) to where you want it to be, remember and add the \ to the end of the path.
                          Change "NewPartNo" to the property of your choice. I've trialled it on 3 parts that had part numbers and now they don't so it works for me.
                          Hope this helps
                          Steven
                              James Kashuba
                              That worked Steven! Thank you for all your help, and Deepak is always a great resource for me. I wish I had a fraction of the API knowledge as he does.
                              Because this is such a powerful tool (the gears are turning) I have to ask one more question. Can you add properties the same way? And if you can, can they be added in such a way that they wouldn't override an existing property. In other words, if I have a 1000 files and 300 of those have the property I want to add already present, would it override its value?
                                  Steven Richmond
                                  James
                                  Try this
                                          swCustPropMgr.Add2 "ProjectName", swCustomInfoText, "TESTING"
                                          strFileName = Dir
                                      Wend
                                      'swApp.ExitApp
                                  This is the line that has been added
                                  This adds a custom property called "ProjectName" if it doesn't already exist.
                                  Change "ProjectName" to the custom property you want and "TESTING" to the value you want wrote to the custom property. I've tested it on 3 files, the first of which had "TEST" rather than "TESTING" for a value and it never over wrote it.
                                  regards
                                  Steven
                                      James Kashuba
                                      Steven, that was great! I didn't even think of adding and deleting in the same macro. This little macro is a game changer for some of the tasks I'm up against. I did notice one thing that I didn't catch the first time and that is it didn't update assembly files only part files. Does the strFileName control this?
                                          Steven Richmond
                                          Hi James
                                          Probably not the cleanest way to do it but I added a strFileName 2 for assemblies. The macro goes through the folder for parts first then goes back through for assemblies.
                                          Dim strFileName2 As String
                                                  strFileName = Dir
                                              Wend
                                              strFileName2 = Dir(strFolderPath & "*.SLDASM")
                                              While strFileName2 <> ""
                                                  Set swModel = swApp.OpenDoc6(strFolderPath & strFileName2, _
                                                      swDocASSEMBLY, 1, Empty, Empty, Empty)
                                                  strFileName2 = Dir
                                              Wend
                                          As I say it works but probably not the cleanest way of doing it.
                                          regards
                                          Steven
                                Deepak Gupta
                                Using TS is bit tricky but is simple once you understand it. Though you can update the macro using bunch of  batch file macros available on this forum.
