Activating a view getting configuration and insert single config BOM
Question asked by Bruce Perry on Apr 24, 2015
Here is the code for inserting a BOM of a view in a drawing.
I haven't clean it up for redundant information that I was using to build it but it works.
Option Explicit
Dim swFeatMgr As SldWorks.FeatureManager
Dim swView As SldWorks.view
Dim swBomAnn As BomTableAnnotation
Dim swBomFeat As SldWorks.BomFeature
Dim anchorType As Long
Dim bomType As Long
Dim configuration As String
Dim tableTemplate As String
Dim Names As Variant
Dim visible As Variant
Dim boolStatus As Boolean
Dim swSheet As SldWorks.Sheet
Sub AddBOM()
Dim swConfig As SldWorks.configuration
Dim MyConfig As String
Dim MyConfiguration As Object
Dim selMgr As SldWorks.SelectionMgr
Dim view As SldWorks.view
Set swModel = swApp.ActiveDoc
Set swFeatMgr = swModel.FeatureManager
Set swDraw = swModel
Set swSheet = swDraw.GetCurrentSheet
Set selMgr = swModel.SelectionManager 'Select View
    boolStatus = swModel.EditRebuild3()
    boolStatus = swModel.ActivateSheet("Sheet1")
    boolStatus = swModel.ActivateView("Drawing View4")
Set swView = swModel.ActiveDrawingView
'I have four view at the standard view names. I want to create the BOM based on "Drawing View 4"
'I want the BOM to be from the configuration (Drawing View 4), so you have to make it the active
'or selected view
'Insert BOM Table
anchorType = SwConst.swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_BottomRight
bomType = SwConst.swBomType_e.swBomType_PartsOnly 'SwConst.swBomType_e.swBomType_TopLevelOnly
swModel.ClearSelection2 True
configuration = swView.ReferencedConfiguration
tableTemplate = "C:Some location"
Set swBomAnn = swView.InsertBomTable2(False, 0.8501, 0.07, anchorType, bomType, configuration, tableTemplate)
'Inserted in the lower right over the Title Block
Set swBomFeat = swBomAnn.BomFeature
Names = swBomFeat.GetConfigurations(False, visible)
visible(0) = True
boolStatus = swBomFeat.SetConfigurations(True, visible, Names)
swFeatMgr.UpdateFeatureTree
