We have a user that had a computer failure while having several files checked out. He can't check in these files because they were checked out on the failed PC. As admin, I know I can undo checkout but that means he would lose the work done on these files.
Is there a way for the admin to check in these files without losing their work?
Steve
Adrian,
I was assuming when Stephen said "computer failure" he meant the files were not retrievable from the computer hard drive. If that is the case, the changes the user made post check out are gone. If the files can be retrieved from the failed computer then your method will work.
