I have an imported part with a hexagonal (for lack of a better term) profile that is, as far as I can tell, on an arc. I am looking to keep this hexagonal profile, extend it, using the arc as a profile. In all honesty I am not sure if I am even on the right path or using the correct methods or functions
I have been able to get as far as getting my sketch plane where I want it and getting the profile setup. The trouble I am having is using the part as a guide curve and extending it to the sketch plane (screen shot below). I have profile views of the part attached.
Not sure if this is what you are looking for:
you can mirror the part using the face closest to plane1 and then cut with the plane1 if that is the look you are going for.
or
Create a spline on front plane using original import and then mirror the spline. I was able to use the spline to do a sweep of the part. Then cut the sweep with plane1.
