Is there a way to:
fix in space the part that I'm applying flex to?
select a fixed plain or one end that doesn't move?
add a coordinate system to a flat bar once and have it stay put through 4 flex operations?
Flex seemed like a handy way to bend the ends of a flat bar at odd angles and then twist the center 90 degrees... until I tried it.
See attachment.
Jerry
hi Gerald,
Yes, the trick is to align one of the trim planes with the triad. You can do this in the property manager or RMB on the Triad In the workspace - depending on what you want to do.
mark
