I would like to use the magnifying glass function, but I have unfortunately remapped the 'G' key to another function long ago. How can I use it without resetting ALL of my hotkeys to default?
Right-click on the gray portion at the top of your monitor to get the list of available toolbars. Select "Customize..." from the bottom. Go to the Keyboard tab and search for the feature. Assign "G" to it. You will get a pop-up saying that this shortcut is already assigned to another function, and do you want to change it. Click yes. That will only change that one shortcut, and leave the rest unchanged.
If you select the short cut button it will sort by short cuts, I then copied into excel, a little editing, printed. and taped the list to the side of my monitor.
The only one that I have added is the Alt+V for Tile Vertically, nice with dual monitors.
