2 Replies Latest reply on Apr 27, 2015 8:30 AM by Bruce Perry
    How do I select and set the justification of a cell in my revision block.
    Bruce Perry
      I created code that will delete the standard revision table and insert a new one and then add a new revision which in turn adds the no., and date. I then add the description Preliminary, I would like to left justify preliminary. Below is a piece of the code:
      'Drawing has a new Revision Block with a new name::get name
          Set swAnn = currentSheet.RevisionTable.GetAnnotation 'Get new Revision Block name
              MyTableName = swAnn.GetName + "@" + currentSheet.GetName
          boolstatus = swModel.Extension.SelectByID2(MyTableName, "REVISIONTABLE", 0, 0, 0, False, 0, Nothing, 0)
              longstatus = myRevisionTable.AddRevision("") 'Add revision
          Set MyTable = swModel.SelectionManager.GetSelectedObject5(1)
      'Variable set below update as needed
              MyTable.Text(1, 2) = "PRELIMINARY" 'Row 2 third column to the right
              MyTable.Text(1, 1) = "X1"
              'MyTable.Text(1, 4) = ""                    'Row 2 fifth column to the right
              'MyTable.Text(1, 5) = ""                 'Row 2 sixth column to the right
