Sometimes Solidworks will dimension with an angle instead of giving length. I thought maybe something didn't line up perfectly, but that's not the case. It shows the center of two holes are 180 degrees apart.
How do I force it to dimension length? I use smart dimensioning, but even when I choose vertical dimension, it still shows an angle.
Thank you.
Are you accidentally picking the centermarks when you add dimensions between holes ? Is it happening when you click the edges of the holes ? Is it a section view on a drawing with tapered holes ? Can you give us a screen shot.?
