I will attach a few pictures that should pretty much explain my issue.
We use a program that converts SW drawings to PDFs (via eDrawings) then arranges them. eDrawings is not showing exactly what SOLIDWORKS is showing, and frankly, I am embarrassed to send this to the shop. These are not the only files with issues; lots came out this way. Is there a way to keep this from happening??? I have hundreds of sheets of drawings needing to go out ASAP.
Thanks for any help/suggestions...
I might as well throw in that I am also VERY VERY dissatisfied with the new eDrawings UI.
Robert Lankford
Just curious, why do you output PDFs via Edrawings (unless I'm misunderstanding you).
Solidworks usually does a pretty good job of outputting PDFs from itself. Does that way produce better results?
