We have appearances applied to individual parts, but we need to add cuts to them at the assembly level, and we'd like to change the appearance of the cut faces in the assembly so that they are easily distinguishable from the original (uncut) parts.
I tried applying the new appearance to the face created by the cut feature, and also to the feature itself, but it won't take. It's easy to apply a different appearance to an individual face within a part, but when the face is created by a cut feature applied at the assembly level, it doesn't want to play ball with me.
Is this possible? Hopefully someone has a trick to make this happen - my experience with appearances is limited at best.
Thanks.
SW 2014 sp5
Win 7 Pro
OK, I got it to work now. I was trying to apply the appearance to individual faces of cut features that had been added in the assembly itself. That doesn't work, but you can add the appearance to the entire cut feature and it works fine. It's easier to do it anyway, since you can get many faces at once.
Note that I'm working only with features that are created in the assembly. For features that are native to a model that has been inserted into the assembly, changing appearances on individual faces works fine. For some reason, appearances of features added at the assembly level can only be manipulated in their entirety, and not on a face by face basis.
Thanks for the help.
