I am trying to pattern a solid swept cut around the face of a cylinder, the preview while still in the Circular Pattern feature shows the pattern I want but whenever I hit the green check-mark to actually build the feature I get an error saying that the pattern failed.
I need to use the solid swept cut for this feature as it is important that the walls of the cut remain normal to the surface throughout.
In my understanding and practice......The patterns are still parametric in that if you try to pattern a swept cut, you have to be able to sweep the cut with the existing geometry. You will see this a lot when trying to pattern fillets. All of the intersecting geometries as Glenn indicated, make it impossible. For something like this, you would be best creating your features you want to cut as un-merged solid bodies. Then pattern the solid bodies, then perform a combine, subtracting the solid bodies from the main solid.
