5 Replies Latest reply on Sep 18, 2018 1:43 PM by Shail Patel
    Check read only status and confirm popup window.
    Alex Graff
      Hello All,
      So with help from people in the forum I was able to successfully create a macro to work through a directory opening each drawing file, deleting an old BOM, inserting a new one and then saving and closing. After getting that working I now realize there is more work to be done to make it user friendly at my work. My goal is to be able to run the macro to run on multiple files at one and walk away. The problem I am having is that we use workgroup PDM and some of the files in the working directory don't have ownership on the computer in use and an error message poos up. I am not looking for a way to take ownership, I am looking for a way to just check if a file is read only and if that file is, just skip it and move on to the next. I would imagine the easiest way to do this would be with an If statement but I don't the the code to check read only status.
      My next catch is I will occasionally run across a drawing that has a pop-up dialog box asking to confirm drawing view update when the document tries to save. Is there a way to have the macro confirm this and move on to the next drawing? Possibly even have box in front of "Don't prompt me again in this session" be checked so it is only a problem once.
      I have the same thing with the pop-up "Component documents must be saved."
      Thank you all in advance for your help. I will post what code i currently have as well.
      Dim swDoc As ModelDoc2
      Dim fileerror As Long
      Dim filewarning As Long
      Const TABLE_TEMPLATE As String = "Revision table template location"
      Dim swSheet As SldWorks.Sheet
      Dim vViews As Variant
      Dim swView As SldWorks.View
      Dim swTableAnn As SldWorks.TableAnnotation
      Dim swAnn As SldWorks.Annotation
      Dim swRevTableAnn As SldWorks.RevisionTableAnnotation
      Const folder As String = "C:\working\"
      Dim files As Variant
          files = Dir(folder & "*.slddrw", vbNormal)
          Do While files <> ""
          'Open files in folder
              swApp.OpenDoc6 folder & files, swDocDRAWING, 0, "", fileerror, filewarning
              files = Dir
          Set swModel = swApp.ActiveDoc
          Set swDraw = swModel
          Set swSheet = swDraw.GetCurrentSheet
          'Delete existing revision table
          Set swView = swDraw.GetFirstView
          Do While Not swView Is Nothing
              Set swTableAnn = swView.GetFirstTableAnnotation
              While Not swTableAnn Is Nothing
                  If swTableAnn.Type = swTableAnnotation_RevisionBlock Then
                      Set swAnn = swTableAnn.GetAnnotation
                      swAnn.Select3 False, Nothing
                      swModel.Extension.DeleteSelection2 Empty
                      Exit Do
                  Set swTableAnn = swTableAnn.GetNext
              Wend
              Set swView = swView.GetNextView
          Loop
          'Add new revision table
          Set swRevTableAnn = swSheet.InsertRevisionTable(True, Empty, Empty, _
              swBOMConfigurationAnchor_TopRight, TABLE_TEMPLATE)
          'Save
          swModel.Save3 0, 0, 0
          'Get title and close
          Dim swTitle As String
          Dim Part As Object
          Set Part = Nothing
          swTitle = swModel.GetTitle
          swApp.CloseDoc swTitle
          Loop
