Attached is a 3d weldment part.
I want to copy the center plate (without the holes) to the same point on the vertical sketch line a little further down.
What's the best way to copy 3d sketches and/or features in a part drawing?
Use body pattern with sketch driven pattern options. You'll have to create a sketch (containing points only) which will define the positions of the patterned bodies.
