Hi, I am relatively new to both softwares as I usually use Pro/E but was given a catia v5 file and made to work with sw. I am able to open the assembly file in sw but i can't see the dimensions even after checking "show feature dimension". May I get some help on how to go about this? thank you so much!
Cheryl,
I believe I answered both those questions already. You can use the measure tool (found under the 'Evaluate' tab) to measure the parts. If you have SolidWorks Pro or Premium, you can use FeatureWorks (found under Add-Ins) to create features and convert the dumb solids to SolidWorks parts. You'll need to assign material properties, then you should be able to run simulation.
