This spring is driving me crazy!
The hook end of this spring dose NOT want to stay consistent per configuration (rotation direction and rotation relative to start).
Anyone with spring knowledge wants to take a stab at it Maybe you could give me a suggestion as to a better way to construct it.
I do not see it right away why it´s behaving like that.
It´s not following the helix in the extended length. Must be something to do with something changing on the way up. You would probably have it solved if you had the extension in the other way.
But I made a workaround that you can use in the the meantime.
